Jakis
β10-01-2022 06:41 AM in
Questions
After beta update my galaxy 23 ultra ΰ€¬ΰ₯
ΰ€ΰ€°ΰ₯ is not charging more than 84%.
Any issue??
Regards,
Solved! Go to Solution.
KVSONS
β10-01-2022 07:39 AM in
Questions
No it not a problem just follow this steps
Go to device care then
Battery then
More settings then
Trun of the battery protection which is limited the battery to charge inly 84% so after turning it off ur phone will charge to 100%
Battery then
More settings then
3 Comments
tripsmani
β10-01-2022 07:07 AM in
Questions
Screenshot
KVSONS
Questions
Battery then
More settings then
Battery then
More settings then
Jakis
β10-02-2022 10:33 AM in
Questions
Thanks for the same...!!πππ
