Where is 'Optimise battery usage' in settings.?
(Topic created on: 10-16-2022 09:06 AM)
KPR
Questions
When i go using a third party app i see 'Optimise battery usage'. But i am not able to find 'Optimise battery usage' in my S22 Ultra settings.
Can any one help.?
6 Comments
Kailashnj
Questions
I could not find it to... it's not showing in any setting
Š
Questions
Tap on "Apps not optimised 🔻"
Then select "All" from the drop down list.
KPR
Questions
I couldn't understand you.
Š
Questions
*Screen recording
hdshah86
Questions
Yeah, you aren't actually answering the question.
The question is how does one access this "optimise battery usage" screen from Settings?
sihorab
Questions
On your S22 Ultra, you can find "Optimize battery usage" by going to Settings, then Apps. Tap the three-dot menu at the top right and select "Special access." From there, choose "Optimize battery usage." Even if you're using third-party apps like those for streaming or browsing erome videos, you'll be able to search for the specific app and adjust the setting. If you're not seeing it, make sure you're looking under the system-level settings, not within the app-specific settings screen.
