Vibration motor randomly starts
(Topic created on: 09-23-2022 08:46 PM)
saurabhdhillon
Questions
Since the update vibration motor turns on randomly and is only turned off if you restart the phone or if some other notification resets the motor.
5 Comments
JoKeR_77377
Questions
Hi Buddy,
Solution worked for me:- Go to sound and vibrations and u check and recheck the vibration sound option. Screenshot_20220924_115444_Settings.jpg
Questions
Yeah I did figure out vibrating the motor again fixes the issue but it's bit annoying
rnarang
Questions
I face the same issue
ganapativs
Questions
Same here, above trick works, happens when you open WhatsApp and wait for 5-10s or just open any chat for me.
IndiaBetaTeam
Questions
Dear Samsung Member,
Greetings from India Beta Team!
Thank you for sharing your feedback. We welcome your suggestion and appreciate the time and effort you have spent sharing your valuable comments. This will help us to improve our services.
Thank you for being our valued customer.
India Beta Team
