Various Issues with Sound panel.
(Topic created on: 3 weeks ago)
NobodyTheGoat
Questions
Various issues with sound panel icons in the beta update. In both of the images I was not connected to any bluetooth device, just a usb c earphone.
**SOLVED**
**Cause-Sound assistant from one ui 8.5 not compatible**
3 Comments
Questions
Not showing volume icon
Questions
Are you using goodlock modules??...if you're using it unofficially, that means it's not samsung's fault
NobodyTheGoat
Questions
Yes it was previous sound assistant version causing , this i updated it manually via apkmirror , because it was no available on galaxy store.
