Anudeepv
09-15-2023 09:33 AM (Last edited 09-15-2023 09:33 AM ) in
Questions
Hi,
Facing high battery drain overnight even in battery saver mode. Charged it to 80% before going to sleep and it dropped to 63% by morning. Below is the usage state and I could see only android system and kernel as the biggest contributors.
Anyone else Facing the same problem?
4 Comments
RĀJ
09-15-2023 09:56 AM in
Questions
Try cleaning the cache partition of the phone through stock recovery. It will address the battery drain
RĀJ
Questions
Have you updated to the latest beta build?
Anudeepv
09-15-2023 03:32 PM in
Questions
Yes this is the latest build and have tried clearing cache as well
Starbug
09-22-2023 01:20 PM in
Questions
Yes battery drain has increased after 2nd update.....Samsung will fix this issue with stable update soon
