Problem πŸ˜΅β€πŸ’«
(Topic created on: 11-03-2023 08:41 PM)
Naman_7499
Questions
After updating in One Ui 6 Android 14 i don't able to use good lock or fine lock modules in my F23 Galaxy device i updated all the modules and reinstall it but it doesn't work properly please fix it or give me idea what i do ??
6 Comments
vinayhsish
Questions
Yes you are right βœ…οΈ
Naman_7499
Questions
Bro now i think problems are solved related with fine lock modules Screenshot_20231104_233434_Google Play Store.jpg
Galaxydian
Questions
Yes, but I tried these modules that are working
Homeup (partially working)
Lockstar
Sound assistant
These are working...bro...
Naman_7499
Questions
Yes but home up not working in my device or lockstar i dont use or sound assistant is working .some works properly but some not !
Galaxydian
Questions
Yes...don't worry after the stable oneui6 update it will be fixed
Akshatag
Questions
Yes
