Resolved! Solved
Double tap to Sleep for Launchers Not Working
(Topic created on: 11-27-2020 01:33 PM)
AtharvaK47
Questions
This feature isn't working for me while using Nova launcher
However it's working for the Default One UI Home
Any idea why & is there a way to fix it?
2 Solutions
jaysharmaaa
Questions
there is option in launchers even in nova launcher for double tap to sleep. it is there for years now.
shail3108
Questions
yes bro you have to enable in the nova launcher. m also using the same and it working fine for me
3 Comments
ketani72
Questions
Nova Launcher developers will have to enable it to work with Nova Launcher.
jaysharmaaa
Questions
shail3108
Questions
