Battery Drain Issue
(Topic created on: 05-23-2026 01:52 AM)
IronMan17
Questions
After downloading the beta update, I'm facing a battery drain issue with my S23 FE.
Is anyone else experiencing this, and are there any workarounds?
IndiaBetaTeam
Questions
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
We want to inform you that the stable software version of One UI 8.5 has been released for S23 series. Please update to the latest software version and if you still face the same issue, we request you to please report this feedback on the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report error is as below:
Open Samsung member application >> tap on support >> tap on send feedback >> choose composer option >> select error >> select the appropriate category >> type your query
Thank you for being our valued customer.
India Beta Team
