Android downgrade problem
(Topic created on: 10-07-2023 02:33 PM)
Nileshverma
Questions
Cannot create a file when that file already exists?
How to solve the problem
And I want back to one ui 5
IndiaBetaTeam
Questions
Dear Samsung Member,
As per your query, we request you kindly share the log file. Without a log file we cannot analyze this issue, Also share video clips and images for better understanding and report this issue with the log file. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report.
After the beta update you will get the stable software version, you cannot downgrade your device software.
