09-18-2020 02:32 PM in
Others- Mark as New
09-18-2020 02:47 PM in
Others• When you are not using the device, turn off the screen by pressing the Side key.
• Activate power saving mode.
• Close unnecessary apps.
• Deactivate the Bluetooth feature when not in use.
• Deactivate auto-syncing of apps that need to be synced.
• Decrease the backlight time.
• Decrease the screen brightness
09-18-2020 04:41 PM in
Others1. Settings >developer option >background process limit >choose no background process
2. Disable auto sync
3. optimise your device often using with device care app
4. on device care app >battery >3vertical dots >settings > put unused apps to sleep
5.Disable always on the display >if u don't use,
6. On the device care app>battery >disable background process which apps consumes most the battery
7. Turn of Gps, Bluetooth when not in use
doing this things can may help your device battery last longer
09-18-2020 04:42 PM in
Others- Mark as New
09-21-2020 11:40 PM in
OthersDear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
