fazal1
Others
Hi friends  my  note 9  not supporting  Samsung gare vr   I installed oculus aap  but that not supporting my mobile
8 Comments
SageSummer
Others
It will support Gear VR.
What is the actual issue you are facing ?
how you are trying to connect ?
fazal1
Others
I installed oculus aap but it's not supporting
Raviijangra
Others
you have gear vr?
SageSummer
Others
What's your VR version? Is it compatible with Note 9 ? does it fit properly ? You have the right adapter ?
Raviijangra
Others
fazal1
Others
ok friends my problems solved thanks for the support
SageSummer
Others
np. 👍
sundarraj
Others
note 9 user and works fine for me
