02-28-2021 07:22 AM in
Others
02-28-2021 07:26 AM in
Others- Mark as New
02-28-2021 07:45 AM in
Othershttps://r2.community.samsung.com/t5/Galaxy-M/Overheating/td-p/3994707
02-28-2021 08:10 AM in
Othersbut many YouTubers saying this phone is not heating....
02-28-2021 08:39 AM in
OthersWhen you turn this feature on, it will disable all those services that run in the background and drain the battery and even lead to your phone heating. Activities like network usage, data syncing, location check, animation, brightness, etc. are all stopped when you turn on the power saving mode. This keeps your phone cool.
To enable power saving mode, use the following steps:
Go to SettingsTap on Battery and device careTap on BatteryTap on Power saving mode and toggle it OnWipe system cache partition
If the issue doesn’t resolve with the above tips, you can try wiping the system cache partition and see if that clears the overheating problem. To wipe system cache partition, use the following steps:
Turn off your phoneConnect your phone to the PC via USBWait until the message shows your phone is being chargedPress and hold the Volume Up key and the Power key.Continue to hold both keys until Android Recovery menu options appearPress the Volume down key and navigate to Wipe cache partitionPress Power key to selectPress the Volume down key to highlight Yes, then press the Power key to selectWhen the process is complete, Reboot system now is highlightedPress the Power key to restart the device
05-11-2021 01:27 PM in
Others
05-11-2021 03:56 PM (Last edited 05-11-2021 03:57 PM ) in
OthersI am not a true Samsung user 😁
I use both oppo and iPhone😅😅
05-11-2021 04:04 PM in
Others
05-11-2021 04:08 PM in
Others
05-11-2021 04:17 PM in
Others
