uuuummmar
12-12-2020 09:49 AM in
Others
My A51 battery is draining out rapidly. I observed continuously for 5 days my battery % comes down every night. Figures are as follows before sleep % and morning %...... 46 - 24 , 32 - 21 , 48 - 03, 56 - 40, 39 - 09. Even I have turned of background apps permanently. This problem comes frequently.. battery drain very fast
3 Comments
Farro7786
12-12-2020 11:40 AM in
Others
it is due to network issue...
just try flight mode at night and then check battery consumption and tell me...
انشاءاللہ problem will be solved...
FarhanMehar
12-13-2020 12:50 AM in
Others
this is happening for a month ago
Izatkhan
12-13-2020 12:57 AM in
Others
yes bro I'm using A51 also and my A51 battery drain very fast Samsung mobile battery life is very bad
