Problems after OREO UPDATES and SOLUTIONS
(Topic created on: 11-30-2018 08:21 AM)
Shiv9564
Others
Problem 1: Random Reboots In case your Android device is getting randomly rebooted or in boot loop, no matter if you are using it or not.
 Solution: You can try to restart your device and check if the Android Oreo update issues like this get fixed or not.If the previous method didn’t work you can try wiping the app cache data. If the problem still persists, reset your device. But prior to performing reset on your device, backup your device using dr.fone – Backup & Restore so that you can restore it after resetting your device.
Problem 2: Sound Problems In case the Android Oreo update issues involve sound problems such as the device sound cuts off suddenly, even when you try to raise the volume.
 Solution: The first solution to this problem is restarting your Android phone.In case a specific app is showing sound issues, then close the app and launch it again.If the problem still persists uninstall that app and try after re-installing a latest version of it.
Problem3: App Problems After Android Oreo 8 update the apps on your device are behaving abnormally.
Solution: App issues are prevalent after every OS update. To combat the issues, you can try the following solutions. Restart your Android device.Update the app to a latest version.Forcibly stop the app, re-launch it and try again.Try cleaning the app data and cache.
Problem 4: Installation Problem Most users face problems while trying to install or update Oreo OS on their device, though, not all of them experience it.
 Solution: To resolve the Android Oreo update or installation issues, you can try restarting your device and then re-installing the update. Your Android phone should work now.
14 Comments
Shiv9564
Others
Feel free to ask questions about it?
nax
Others
thanks bro
Nihalraj
Others
Shiv9564
Others
welcome
prasad66
Others
after oreo update in J7 Pro the ringtones sound is off. what can be the reason.. I had restarted the mobile one time
Shiv9564
Others
If problem continues take back up of your personal things and try factory data reset
VSDevarakonda
Others
@prasad66 can you please share more details like the ringtone sound is permanently off even for the default ringtone or for custom ringtone
Not applicable
Others
That's a bunch of useful information. Thanks mate. 😀👍🏻
Shiv9564
Others
welcome
