Problems QnA#3
(Topic created on: 01-24-2022 04:35 AM)
MuhammadAhmadMaqsood
Others
If you are facing any type of issues regarding your device than you tell me. I'll resolve it, if possible
اگر آپ کو اپنے موبائل سے کوئی بھی مسئلہ درپیش ہے تو آپ مجھے بتا بتائیں میں مسئلہ کو حل کرنے کی پوری کوشش کروں گا
7 Comments
iwqskh
Others
Mera A52 froze k baad restart huwa tha..
Others
The mobiles battery is about too cold that it is required to restart(for heating up the battery and for bringing back to their normal working temperature) so that there is no serious issue caused like battery damage
Others
ZohaibSquare
Others
A51 auto restart problem
Others
It is because of harmful apps you installed in your device. You can perform a software update, factory reset, or turn on Safe mode to determine if an app is causing the auto restart issue.
SyedUsama1915
Others
Jazak Allah 😊 brother.
Others
