NOBODY1
11-04-2023 12:31 AM in
Others
How do I update the system running my phone to the latest version of Android from the settings of the phone itself
3 Comments
MOQBALI
11-04-2023 05:40 AM in
Others
To update your Android phone to the latest version from the settings, you can follow these steps:Open the "Settings" app on your phone.Scroll down and look for an option like "Software Update," "System," or "About phone." The location may vary depending on the brand and model of your phone.Tap on that option.Look for an option like "Software Update" or "System Update."If an update is available, you should see an option to download and install it. Follow the on-screen instructions to complete the process.
Zammi
11-04-2023 07:01 AM in
Others
Are you facing this error for long period of time? Maybe a server side error (they are temporary). Try again to see if it works now.
speedrunningban
11-07-2023 06:54 PM in
Others
F#ck off man
