Resolved! Solved
Need Help Veirifying My 45W Samsung Adapter for my S24 Ultra
(Topic created on: 05-05-2025 06:05 AM)
Lahik
Others
Hey Samsung Members,
I recently bought a 45W Samsung Travel Adapter for my Galaxy S24 Ultra, and I want to make sure it's genuine. It has the "Travel Adapter" label, model number, and a serial number. I followed the checks mentioned on the official Samsung website, and everything seems fine — but I’d appreciate some expert eyes or tips to be 100% sure becuase I don't want any issues on my phone.
Is there any official way to verify the serial or model number directly with Samsung or through a tool?
Thanks in advance!
Others
"45W PD Adapter" that is not samsung font , that's why I mentioned this is Grade A. Orginal font should like the image below. If this comment helped you in any way, please consider hitting the 3dot menu and accept as a solution 🙏MDDnlpXb4o.jpg
8 Comments
Others
From Where did you buy the adapter? Price of the adapter and send the images of the box and adapter also
Lahik
Others
I bought from a local store called call point in Sri Lanka. They are legit but still I want to make sure that is original. I bought it for Rs 7500 with 6 months warrantycmHfzjnpsE.jpgl4J6uotGpF.jpgWE4pIExu6B.jpgS0hg2kbErs.jpg
Others
That box is suspicious!! Not samsung fonts.
Nowadays, Grade A one and other fakes also use the serial that corresponds to a genuine one. So you can not tell the **bleep** and genuine by checking the serial. And also genuine one cannot buy for Rs 7500. Please send the top photo also. ( plug side of the charger )
Base on the my experience this is a definitely a Grade A one
Others
That's not genuine, bro. Yoh can register products on this platform. Try it
Lahik
Others
I think it is the legit one because they had an A grade too around Rs 5500 and I checked from other sites, the price is bit higher around 9k- 11kEVXyZt1nrl.jpgQIgMzWeDGG.jpg
Others
Lahik
Others
Even in the official samsung website you see the can see adapters got around 1.5 out of 5 rating because of their poor quality. Some of them are suggesting to buy an A grade one because they work perfectly fine for more than 3 years
Janith842
Others
From the photos you sent. This is not an original 45W adapter, Bro. It's a high Grade A copy. You can buy Original 45W and 25W adapters from Authorised Centres such as Jkoa, Mobitel, Dialog, and Sinhagiri.
I also can't find the original chargering adapter, so I am still using the original 25W adapter, which came out of the box of my A72.
If my comment helped you in any way. Please consider hitting the 3 dot menu of my comment and accept it as a solution. It helps me a lot.
