Gear Fit2 Pro Floor Counter Problem
(Topic created on: 09-05-2018 07:50 PM)
HrithikGeet
Others
The floor counter of my newly purchased gear fit2 pro is not working properly. When i climb a floor, it mostly does not counts that i climbed a floor. It is very rare that it counts the floor that i climbed. Please help me for this as i was expecting a good performance from this watch But it is not up to the mark.
2 Comments
admin_
Others
Thank you for being with Samsung and sharing your concern. We would like to offer some troubleshooting steps to overcome the issue:
1) Disconnect the Gear from the device and connect again to check the issue.
2) Navigate to Settings >> Apps >> Gear Manager >> Clear Cache.
3) Reset the device settings by navigating to Settings >> General Management >> Reset >> Reset Settings.
Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
sol
Others
I climbed 18 floors and it recorded just 10 ... took a break on floor 9 and 15 .... the counter does not work properly. the procedure above has no effect ....
