Highlighted
Battery is draining rapidly even after January update. Did all the solutions as told by Samsung customer care executive but battery is still draining. Hope this problem will get solved in the next update for Samsung Galaxy a50s.
18 Comments
Highlighted
same problem in a50. Samsung have no any solution of this problem. I visited service centre and they change motherboard and battery but problem not resolve.
Highlighted
same problame may A50 bigger problems
Highlighted
it's look like a Software issue it should fix through an update
Highlighted
Yes definitely.
Highlighted
yes facing the same issue!
Highlighted
Beginner Level 4
same
Highlighted
all Samsung mobiles are facing battery draining only after January update.
Highlighted
my same problem
Highlighted
Same here.
