Battery drain.
(Topic created on: 03-28-2026 05:29 AM)
Shahzx
Others
Main thing i hate about Samsung phones is the random battery drain after security patch.
Doesn't happen every update but does happen sometimes and its very annoying and there is nothing you can do to fix it besides factory reset or wait for next update.
In my case i am getting 3 hrs less battery timing.
From 5hrs screen time 48% used.
To 2 hrs screen time 52% used.
3 Comments
NasirRehman
Others
Better Reset your phone After Update if you're continuously facing issue
Shahzx
Others
Cache partition has officially been removed by Samsung.
In recovery menu you can only factory reset.
Shahzx
Others
They switched to A/B system
Watch YouTube video that will explain it.
