Battery Problems -S22 ultra
(Topic created on: 05-23-2022 09:23 AM)
Manutd1987
Others
Am really done withy battery , i have no idea what is google play services process causing my mobile battery to go crazy without using it.
My battery is draining in less than 5 to 6 hours without using it .
Am using all original Samsung products .
When i speak to the support they send me send your phone for diagnose in the nearest service center .
What is the solution for this!.
Thanks ,
Moutaz
#battery #batterydrain
2 Comments
Others
Maybe it's because your apps have now been updated? Try restricting the mobile data usage of the app and the app itself in the background and see if it helps.
Manutd1987
Others
It has nothing to do with the data , i did restriction but its useless. Am really disappointed now , my vivo x60 pro with smaller battery is performing better than my s22 ultra in terms of consumption:( today i charged it more than 2 times in full with normal usage :(
