Auto Rotating Problem with my Samsung S8+
(Topic created on: 06-27-2019 08:27 PM)
bluegemarcher
Others
How will I get rid of this Auto Rotation? Can someone help me please...?
14 Comments
bluegemarcher
Others
Tomorrow, I will try it again. For now I have to sleep brother. Thanks for the links.😊 Talk to u again tomorrow. Thanks!
Others
If VPN is your issue, U must install WINDSCRIBE VPN. It's the only one which gave me 100percent result when I tested..
Others
Dear, if you download goodlock with out VPN it will not work. You have to install all the modules and then install nicelock app instead of goodlock app.
bluegemarcher
Others
Ok... Tomorrow I will try. Thanks!
Others
If there is any issue with Goodlock especially if it shows server error, that's because Goodlock needs to connect to server when it's configured for first time. If you always get server error, then the VPN is not working or VPN services may be restricted in your country. What you can do is, install the list of apps I mention here from the link I provided. It will work.
1. Nice lock
2. LockStar
3. QuickStar
4. Task Changer
5. Routines
6. ClockFace
7. MultiStar
8. NavStar
9. Nice Shot
10. NotiStar
Use Nice lock app instead of Goodlock.
