71 sound problem
(Topic created on: 08-16-2022 02:01 PM)
wano02
Others
Hi guys my a71 suddenly started to have sound problems. The sound just goes softer then back to the max volume can yu please assist thank you.
3 Comments
Tsogo_sam05
Others
Hi
When do you experience these sound problems, is it during getting calls, playing music or using other features? How long have you had this issue with the phone? Did you update the software of your phone?
wano02
Others
When I played songs it's gonna be a month now
Tsogo_sam05
Others
We recommend that you download the latest software update, then try again. If this does not resolve the issue, follow the troubleshooting steps below.
1. First, remove anything that is plugged into the headphone jack, such as selfie sticks or headphones. Also, remove any cases or protective covers that could be muting the sound or blocking the speaker.
2.
Your phone's audio might be being redirected if your phone is connected via Bluetooth to your wireless headphones or a wireless speaker.
1. Go to "Settings", then tap "Connections".
2. Tap "Bluetooth".
If your phone is connected to another device via Bluetooth, the audio might be playing through the other device. Check and remove the other device if you'd prefer to play the audio through your phone's speakers instead.
3.
Check to make sure that your phone has not been accidentally muted. If the sound is not loud enough during a call, try maximising the volume to the highest level. During a call, press the Volume up button on the side of your phone or you can test the sound from the Settings menu on your device.
1. Go to "Settings", then tap "Sounds and vibration".
2. Tap "Volume".
3. Slide the bar to adjust the volume to your preferred level for each type of sound.
4. If the sound coming from your phone is muffled or muted, it might be because the speaker is wet or blocked. Gently brush the speaker using a dry toothbrush to clean any obstructions. Test your phone afterwards to see if the sound has improved.
5. Restart your phone
1. Press and hold the Power button for a few seconds until the Power menu pops up. Tap Power off.
On phones without a dedicated power button, swipe down with two fingers from the top of the screen to open Quick Settings. Tap the Power icon at the top of the screen, and then tap Power off.
2. Once the phone shuts down, wait 30 seconds, and then press the Power button to power on your phone.
