rubbenmogatal
01-20-2025 12:33 AM in
Mumbai
I'm using earbuds 3 since 5/6 days today I noticed my left side buds are not getting charged from earbuds case so wht can I do now ????
2 Comments
Abhiisam24
01-20-2025 02:07 AM in
Mumbai
Bro that is sad to hear. I faced the same problem but that was just of some deposit on the charging small pins after cleaning all the things properly and resetting it from the app. Got all good then.
Try once if it helps. By the Samsung wear application.
rubbenmogatal
01-20-2025 10:58 AM in
Mumbai
Ok bro sure I'll try
