05-05-2025 09:38 PM in
Galaxy Z- Mark as New
05-06-2025 09:47 AM in
Galaxy ZDear Samsung member,
We want to inform you that we are currently unable to access the shared link regarding the ongoing issue. Please perform the below-mentioned troubleshooting steps, these may help in resolving your device battery drain concern.
9. Reset the device:
IMPORTANT:
• For this:
