Low network reception problem in Fold 4
(Topic created on: 03-16-2024 09:13 PM)
jpskurukshetra
Galaxy Z
Samsung phones have low network reception problem.
Same sim card works quite well in other company devices ( oppo redmi Vivo oneplus ).
But all Samsung phones have same low network reception issue.
9 Comments
aapy
Galaxy Z
I think you need to reset your data setting
Galaxy Z
I tried everything from resetting network setting to factory reset.
Nothing works.
Suprising thing is that same sim card works well in vivo/oppo device at same location.
I spent 150k on fold 4 and phone doesn't receive proper network.
Chendil
Galaxy Z
Same problem Samsung s24
Galaxy Z
Samsung should release an software update to fix this
umesh30
Galaxy Z
You are right. I also face lower network coverage sometimes...
goodthings
Galaxy Z
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time, restart your's device without any Sim in slots also interchange Sim in slots, turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy Z
Your's most welcome to here.
cs_member10
Galaxy Z
Dear Samsung Member,
Kindly check the device in a different location/network coverage area.
Check device network mode settings: Settings> Connections> Mobile networks> network mode SIM1 or SIM2> Select network mode(set device network mode as 5G/LTE/3G/2G (auto connect) mode.).
Check network operator settings: Settings> Connections> Mobile networks>Network operators> Select automatically> OK> Registered on the network.
Note: We recommend setting device network operators as automatically.
Reset settings: Settings > General Management > Reset.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Galaxy Z
Stop your outdated suggestions.
Release an software update to fix the same.
