will bixby be available for s7 edge
(Topic created on: 04-06-2017 07:04 PM)
kavi3
i would like to know whether the new ai assistant bixby will be coming for the SAMSUNG s7edge in any future updates.
9 Comments
Rotarytitan5
yes it will come to s7 with oreo update
Rani2
when oreo update is rolling out for s7?
Ady1
how do you know?
niransamawy
i know cortana will come for android
19961
يعني في تحديث قادم ل S7 بحمل تطبيق بكسبي
mouaaad
if it will with came with the next update
don't do it is better we need it now nit after 6 months or more
Bilawal
no
only for s8 s8+
Mbithuka
You can install Bixby from apkmirror.com But some functions are not included like the image recognition or voice input
riyaszz
all apps are fake. dont try. it will affect your old touchWizard.
Bixby supports only s8 and s8+
