Resolved! Solved
wifi data cycle settings problem
(Topic created on: 04-21-2020 12:32 AM)
Not applicable
Hello members...I am using galaxy s9 on android 10 ...here inside connection settings, I can't change data cycle month for wifi...it's fixed..can you tell me is it possible in android 10?if yes then please provide settings here...I am attaching screenshot of that particular 👇
3 Solutions
A34_5G
to change mobile data cycle, first turn on your data and then change the cycle. Wifi usage cycle shows how much you have used wifi in the past month.
ShahidBD
This feature is not provided for WiFi. I think this only applies to mobile data, as it is usually private and expensive where Wi-Fi data is usually served institutionally.
rodentia
i know i'm late to the game, but if you're still looking for a solution... i actually use a third-party app (download in google play) called "Data Counter Widget." you can configure both mobile data and WiFi usage w/ different dates which is great b/c my internet cycle isn't the same as my cell.  you can go into the app which breaks it down by app and filter just mobile or just WiFi if you want.  plus the widget shows a running balance on your phone screen (wherever you put it) for quick numbers.
don't know if this comment will go thru since i'm suggesting an app, but if it does and you see it, i've found it to be very handy! :)
11 Comments
A34_5G
Not applicable
if there any option to change wifi data cycle like from 2nd april to 21 th April something?
A34_5G
no
Not applicable
ok
ShahidBD
Not applicable
yes I understood .....you are correct..
ShahidBD
Thanks
kaustubh10
bhai biling cycle change karke dekhle
ho jayega
Not applicable
uo fixed hain wifi ke liye
