when samsung will fix s10 plus battery drain issue?
(Topic created on: 01-23-2021 09:16 PM)
nripen00
When samsung will fix s10 plus battery drain issue and wifi connectivity problem?also there are some problems on camera as well.if there was some issue with latest one ui then why they launched the update for galaxy s10 plus? Really disappointed
10 Comments
Notadeveloper
They have paused the rollout, a fix is coming soon
nripen00
I know about the rollout,but they need to solve this issue as soon as possible users who have already been upgraded.
iamrohitkm
I am not facing any wifi issues in my S10 after android 11 I did reset after the update.
Nshant12
same issue auto restart
nripen00
wifi connectivity issues there,unable to find wifi connection some times
money990
yes true bro i m also facing the same and when someone call if the phone he is keep at some distance the other person cant hear our voice ealier this was not there i have aslo udpate to stable verison of a11 on first day
nripen00
I am using s10 plus and the issue is there
Shahanewaj
Yes Bro Same In S10e Battery Drainage Is too High.
cs-member13
Expert Level 4
Dear Samsung Member,
Please be assured and to resolve "wi-fi" issue kindly follow below given step:-
>>Forget the Network:- Go to apps screen > Settings > Connections > Wi-Fi > Wi-Fi network > Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
And to resolve "battery drainage" issue please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
And to resolve "camera" issue kindly follow the given below step:
 >>Please clear data or cache of Camera Application(Tap Settings > Apps > Camera > Storage > Clear Cache/data).
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
