Highlighted
I always watch YouTube videos for piano playing,
The problem occurs when i set the playback speed on YouTube to (0.75, 0.5 or 0.25) the output audio from my S20+ will have echo and not nice.
I tried with my other old iPhone mobile, the voice there is pretty good and have no echoing, it's just slower.
Thanks.
6 Comments
Highlighted
โ˜…
Hi, try to long press the YouTube icon for one second then select App info > Storage > Clear Catch, let me know if this will solve your issue.
Highlighted
Still same problem.
Highlighted
โ˜…
Try to go to YouTube using the phone browser and check if the issue exists still, to make sure this issue caused by the phone or the app.
Highlighted
Same issue even using the phone browser.
I noticed Android devices have the same issue. I might be wrong, but i tried with another Android device, it's same.
Highlighted
โ˜…
Actually I can't tell you more unless I check your device, but I'm using Note 8, Note 9, Note 20 ultra but never noticed any echo while using YouTube on lower speeds.
Highlighted
My device is new, not even 2 weeks i used.
