smart wifi connect
(Topic created on: 10-30-2019 05:09 PM)
Gabe
Hi Samsung,
I love my s10. Its very good. I love my phone.
However. I would like to make a suggestion on am improvement for the wifi connectivity.
I have 3 wifi networks at my office, and 2 at home.
My phone always stays connected to a network even when im far from it, and in range of a stronger wifi link.
I find that even if the signal is too weak to transmit, but strong enough for the phone to stay connected, i have to manually change to the stronger network. I find that as this happens, the phone may be comnected but however, it too weak a signal to transmit any data.
I would like to see a situation where my phone can connect to the strongest saved wifi connections automatically as i move between spaces, to keep me connected.
Food for thought samsung tech team. I know you can make this work.
Warm regards
Gabe
6 Comments
MFaz
having the same problem here 😐
alhalhindi
Beginner Level 4
same problem here
Gabe
seems its a universal issue. i would like the smart wifi feature. would save time when im on Skype or whatsapp calls
Samsung_specialist
Hello Gabe, thank you for the suggestion! We will take it into consideration. :)
Gabe
hi samsung specialist.....im still waiting for my resolution to my wifi turning itself off and my smart wifi solution....👀🤔
Samsung_specialist
Hello Gabe, please visit the nearest Samsung Service center with the device to have it checked 😊  http://www.samsung.com/ae/support/servicelocation/
