samsung s7 edge not showing volte support
(Topic created on: 07-18-2017 03:53 PM)
ehtesham
I am using samsung s7 edge bought from UAE using in India with 4g volte support sim (jio)
But unable to use volte support
Please advice with proper solution
10 Comments
Phoenix7
if you want volte option, you need to change to indian firmware. uae firmware for s7 edge have no volte support till now...
ehtesham
Ok how to do that?
Phoenix7
go to sammobiles.com download firmware for your phone. (put model number to search. ) download india country( INS CSC) firmware.
flash it using odin..
you can check youtube for tutorials.
ehtesham
Ok bro will do and let you know....is it risky to change firmware...regarding other features of mobile
rizwib
what features can not be used? after change the firmware?
Phoenix7
all features will be working fine. dont root your device. just flash with original indian firmware... so it wont trip the knox or other securities...
rizwib
do you have tutorial for flash firmware?
pariiiii
i am using samsung s7 edge but i am facing smart view problems on the smart led samsung tv..
please advice how can it b solved n work.
jubi1
i still i am facing same problem.i have doubt can i get official android update after flash firmware on my s7 edge
