Highlighted
After update my samsung notes not working please help. Galaxy S9
4 Comments
Highlighted
check for updates.may update can fix the problems
Highlighted
uninstall and reinstall, and everything will work
Highlighted
Try to Clear Data from Settings-->Apps.
on a different topic, how is your Battery of your S9 doing? Is it good? how much screen on time are you getting?
Highlighted
Hi dear,
Can you explain what error you are receiving while using the app?
