samsung Galaxy S20 FE Battery Draining.
(Topic created on: 01-07-2021 07:39 PM)
Aadilkhan
Before a month i purchased Samsung Galaxy S20 FE. While using mobile i noticed that battery drain very fast even when i used in power save mode it also drain, so please fix it in January security patch.
10 Comments
Notadeveloper
Firsy thing 120hz is battery hogger, second thing exynos 990 not optimised well on Fe indian variant. So idle drain might be too much + 120hz extra drain. If you using with battery saving then, blame processor optimisation or active drain is high which is software side. Most of these issues except consumption of 120hz can be fixed with software update :)
Aadilkhan
even use in power save mode i face battery drain so tell me how it can be fix.
Notadeveloper
You need wait for Samsung to fix it through a software update. I already told you exynos 990 not optimised on Fe well. And maybe software side high active and idle drain. There is no other fix for battery drain other than waiting for Samsung to provide you an update.
sakthikings
Samsung launches worst mobile of the year 2020 Samsung galaxy S20 Fire edition
Notadeveloper
Lol its true, you know wut you are offending some indian FE users ( not me lol) . I will blame Samsung for not launching global variant of FE with sd 865. Btw how is oneplus 8 Pro, any screen issues 😊, and how is oxygen os 11. I skipped it just coz there no service center at my place and i had pretty bad experience with oneplus customer care on my old oneplus 7, so if my screen is fckd up with those issues again, it will be hard for me get it replaced.
Abhi9494
I am not finding any update in my device m 11 plz tell why
Aadilkhan
i think your device will get quarterly update.
Samsung_Support1
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
K1978
i had not 10 and i switched to S20 FE thinking battery back up would be better howere it is giving me even less SOT. less than 3 hours on standard mode(60hz). very poor life. thinking to return the phone
