s9 plus charging problem
(Topic created on: 12/21/19 10:04 AM)
yajeel
Why is my phone not charging when it is turned on? There is no indication of moisture detection. Thanks a lot
4 Comments
Billx
can you advise what message you are getting when you plug in the cable?
Sahaxp
change cable
MrKuzey
I suggest you try a different charger first. Turn off developer options in settings. However, if the problem persists, I suggest you contact Samsung Service.
Samsung_specialist
Hello friend, we are sorry to hear that,
can you please try a different charger cable, if it still didnt work, we advice you to visit the nearest service center with phone to be checked.
thank you :)
