Highlighted
Why on flight mode s9 plus battery drain s like a hell from 15% to 6%.. it drained... bt this doesnt happened for last 1 yr bt for the past 2 days its happening...
5 Comments
Highlighted
it's because of last security patch update problem ,don't worry this time Samsung look after that..in next update just install security patch by switching on download booster option and try to install it fast
Highlighted
ok bro
Highlighted
don't worry, I am saying it because..most of device getting same problem as you are facing..it's happened for skip file pass issue....thatswhy I allaways try to download it through Samsung service center or by switching on both wifi and mobile network by means of switching download booster 👍
Highlighted
my s9 plus on 15% battery
to 1% in just a minute and switch off... what can I do..
Highlighted
battery need to replace
