s9 plus_ battery issue
(Topic created on: 04-05-2020 08:13 PM)
Abhishek086
My s9 plus is shutting down even though I have 15% battery left. Any fixes?  Note- Its running on optimized mode.
14 Comments
Not applicable
get your battery replaced
Dude He Is asking Solution 😃
The Best Solution is you can Just Move On S10 Or Note 10 Series🤪
Not applicable
wow why would is suggest that
Ashwin98
Replacing with new battery is only the best way or other idea is to use it with power bank....
immi007
bro that's because the calculation of battery percentage has gone wrong
do this
Go to dailer app
enter
*#0228#
there your fuel gauge(battery calibration) will be reset.
your phone will be discharged to 0% and you should charge it to 100 % after that.
immi007
Resets the battery callibration completely..
Abhishek086
ok I will try this and check..thanks
immi007
tell me if this impoves SOT....
Ashwin98
Once technique to calibrate the battery, whether this will improve the battery standby?!!!
