gravereaper
07-25-2017 02:35 PM in
Has anyone noticed that after the recent update S8 plus selfie camera is capturing even more soft pictures ...Firstly it used to process soft images ..Now after the update it's even more .
it's more visible in low light photos.
In daylight ,if you zoom you will spot the softness .
Kindly, advise if anyone ever faced this issue and a workaround or solution if there
admin_
07-25-2017 04:22 PM in
"Thank you for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors.
1) Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity)
2) Turn on the Auto Flash (If Available in the Device)
3) Reset the Camera (From the Camera Setting)
4) Software update via FOTA,Kies or SMART Tool".
