s7 edge voice echo problem
(Topic created on: 05-02-2017 04:12 PM)
Sandy2806
Recently I changed my display for s7 edge. everything works fine except echo problem at receivers end. this is really annoying and need help. as per repair store did factory reset and also update but problem not solved. on speaker and headphones this is working perfectly.
8 Comments
shiv2308
Maybe an issue from your network provider. Try some other network.
Sandy2806
No issues from network provider, it works well when we put phone on speaker or insert headsets.
pir8rider
switch another network Sim card and check the problem still persist
Sandy2806
Tried but same problem.
pratap
No solusation battery changing reamening time......
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create ->
sandeeps004
i am facing same problem any solutions ????
saurabhnikh
Same problem , in samsung f62, repaired phone 3 times within warrenty. Issue still persist.
Never buy Samsung mobiles
