Sam737
Beginner Level 5
03-21-2016 05:02 PM in
I transfer from my iPhone to s7 edge I heard about the device is powerful from Samsung but unfortunately the device is over heating & some other issues like on the edge when you try to press NO 1 is hard I hope Samsung fix those issues soon
5 Comments
BVB
04-07-2016 07:01 PM in
it's a normal issue that heat is generated by using electrical goods, especially when charging the phone or high usage, if gets hot when no function were used, then you have to drop your mobile to samsung's service center. you can find the service center locations in samsung website
UsamaAliRaja
Beginner Level 4
05-11-2016 04:57 AM in
because of heating the Battery is not giving good time
Joynts
03-08-2019 03:16 PM in
s8too
Joynts
Joynts
Lets hashtag it
