Rahulmk
06-02-2018 06:59 AM in
can i replace only the front glass of my cracked s7 edge without the display replacement
5 Comments
Shahjng
06-02-2018 10:44 AM in
yes ....you can change
miansalmanahmed
06-02-2018 11:23 AM in
is the touch quality same or change after replacement?
Shahjng
06-02-2018 11:30 AM in
avail multi quailty depends on you
Rahulmk
06-02-2018 12:35 PM in
does glass only replacement effect my water resistence
pranavshaji
06-05-2018 10:39 PM in
i think you can only change the whole display, glass only replacement is not done by Samsung
