Highlighted
my s7 edge getting more heater even i completely reset my mobile what problem is this can anyone say me what problem is this and what can i do
5 Comments
Highlighted
yes i also have heating problem
Highlighted
bro i think it will solve in oreo update
Highlighted
screen res 720 p ...solve ur prob
Highlighted
it's due to heat which is comes from sun.. the glass of the phone absorb the heat that's why use face it.
Highlighted
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
