MayurMatani
10-16-2018 08:23 PM in
7 Comments
帕里克
10-16-2018 11:11 PM in
exchange it
MayurMatani
10-16-2018 11:29 PM in
rather than exchanging samsung should release a new update which will fix it
ipg
10-17-2018 01:02 AM in
factory reset
Raviijangra
10-17-2018 10:56 PM in
right
MayurMatani
10-17-2018 11:19 PM in
i tried factory reset but it didnt work at all
abhisheknagar73 4
10-19-2018 03:04 PM in
Not sure if Samsung is intentionally degrading the usage of older versions. I've myself experienced significant battery drain post September update. Samsung should seriously focus on battery drain in its next update..
admin_
10-28-2018 11:14 AM in
Thank you for being a part of Samsung community. We apologize for the inconvenience you are facing in the device after the update. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
