s6 edge plus overheated
(Topic created on: 06-11-2016 12:52 PM)
razz1
when I playing games, using Internet, fast charging that time device heat up ! any solution?
4 Comments
MSMYahmadi
don't play too much while charging
rel0aded
Try downloading samsung game tuner and reduce the settings of the game so it reduces the cpu load thus reducing cpu heat as well. Battery heat will always be present when fast charging.
charging1
Khan8
it is normal for the device to heat up while fast charging. don't use heavy stuff while charging
