charmsne
11-26-2017 04:48 AM in
I have s6 edge plus phone.its fast charging feature is suddenly not working..even it is not getting connected to pc..only cable charging
tried a lot of things
1.changing cable,adapter,original Samsung fast charger from Samsung store
2.wipe out cache
3.factory reset
4.samsung tutor which was unable to connect bcoz dey have some technical issue
5.fast charging feature is already enabled from settings
please help me with this problem..
2.wipe out cache
3.factory reset
2 Comments
admin_
11-26-2017 03:51 PM in
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
kumayl12
06-06-2018 05:23 AM in
same problem here i have already feedback as error
