s24 ultra consuming too much battery when screen is off(4% per hr). Suggestions?
(Topic created on: 05-13-2025 05:22 PM)
ubaid047
10 Comments
ahmadmahmood
sale kr do bhai
ubaid047
loss zyado hoga bht
ahmadmahmood
to lena hi nhi tha na
ubaid047
yara solution ka pucha hy...nhi pata goh jao
Qaisar308
Try the following
1. Turn off wifi calling and VoLTE
2. Set extra apps to restrict battery when not in use
3. Optimize phone memory before turning off screen or clear all recent apps
4. Make a sleeping routine to auto turn on battery saver when phone is not in use or while sleeping... also create sleep mode widget to home screen for quick access
5. Turn off wifi and mobile data. if not, then set all the apps notifications to bubble notification + not to on screen when notification is recieved
Hope it will work
+ One ui 7 causing battery drain on s24 series, so wait for update fix
ubaid047
thnku❤
ubaid047
jo battery drain hoti...batery usage may show he.nhi hoti k kis app nay use ki hay
Qaisar308
Wo ya to system k under show hogi ya one ui home k
Lekin yeh update sy fix hojaega
Apa yeh sb Settings try kr k dekho phir btana
Or 1 bar flight mode on kr k test krna apps clear krny k baad
ZainSajid
Put all useless apps into deep sleep and at night use power saver mode and dark mode
