s22 ultra battery drain so fast
(Topic created on: 03-15-2022 06:07 PM)
gilbert
hi just wondering it was advertise that s22 ultra can last for a day. but mine was 100% but after 20mins of usage it drops at 75% and when i reached home 6am til 4pm my battery is already down to 2%.
13 Comments
Ahmadghafar
My god same, worst battery life than my s9. 4hr of screen on time, I will take it tomorrow for refund
ghani28
New device will learn your usage pattern and then only you can expect a good battery life, check on what firmware your device is, as far as i know i got an update recently and have seen some improvements...all in all it delpends on each user usage as well....
gilbert
that is what i see from youtubee as well. so maybe ill just keep it for a while but if after a week still on the same situation i will return my unit
mahmoud1
Did you update the device? Didn't check the battery usage?
gilbert
the laat update i did was when i receives my unit which was last saturday
gilbert
the latest security patch is from March 01, 2022. i hope this was the latest.
ghani28
Yes this latest, but we will get another update soon....
wasi76
Yes same here battery draining fast. In battery comparison my iPhone 13 Pro max is far better than s22 ultra.
gilbert
definitely that iphone pro max is more battery juice than s22 but im not expecting to this point. ill be waiting for a week as mentioned by some users that the phone is calculating the usage first before it will change it battery consumption
