s10 plus charging issue
(Topic created on: 12-12-2020 12:34 PM)
umermalik404
Hi! Anyone here using s10plus and facing issue like fast charging isn't working and onlu cable charging is working which takes more time desipte uding original charger?
Thanks
8 Comments
jangg
change cable
umermalik404
i have changed the cable even adapter
issue remains same
AmmarJaved
it happened with me as well after charging my phone on UPS. Try to change the socket.
umermalik404
i tried this too
and i am facing this issue from past 2 weeks
arbabazhar
u have to change mobile charging circuit which costs u 3-4k
user9992112
if you have changed cable and adapter of the phone then make sure to check your phone settings and check if fast charging option is on.
Go to settings and search for "Fast charging" in search bar. Turn it on if it is off.
umermalik404
no this isn't an issue in my case
