Highlighted
Samsung is making a fool out of its customers. So poor battery life on so called flagship s10 plus
Updates should improve performance where as after every update the battery performance is degrading. Was easily getting upto 7 hrs screen on time on qhd+ resolution earlier now i can hardly reach 6 hrs SOT on fhd resolution.
Not what we expect from a battery capacity of 4100mah
Issue encountered after july update
6 Comments
Highlighted
Bro, there is no solution to this problem, samsung is not at all listening to us, such ignorant behaviour, didn't expect this from the brand like samsung. In starting, i was getting almost 8hrs of SOT on qhd+ but now only 5hrs that too on fhd+ ( battery usage 100%-25%). Battery life is getting worse after every updates..its, just 6 months old device..aage kya hoga..
Highlighted
I hate Samsung Battery performance as i am using note 9 and i have even visited service center and then also the battery life is not upto my expectations
Highlighted
did you replace your battery?
Highlighted
SAMSUNG S10 +Very bad mobile battery drain very fast hunking problem
Highlighted
no they just did something and the battery life improved for a day or two
Highlighted
will battery replacement solve d issues or entire hardware replacement??
