s. pen mine. is not connecting air actions
(Topic created on: 11-12-2025 07:04 PM)
keithjack
kindly assist me my s22 ultra s pen is not connecting air actions
Hi keithjack
When your S Pen on the Galaxy S22 Ultra isn’t connecting for Air Actions, it usually means there’s a pairing or Bluetooth issue. Follow these steps carefully:
🧭 Step 1: Basic Checks
1. Insert the S Pen fully into its slot and leave it there for about 20–30 seconds — this allows the phone to recharge and reconnect it.
2. Ensure Bluetooth is ON →
Go to Settings ▸ Connections ▸ Bluetooth → make sure it’s enabled.
3. Battery: The S Pen needs charge for Air Actions (the pen charges in the slot).
🔄 Step 2: Reconnect the S Pen Manually
1. Go to Settings ▸ Advanced features ▸ S Pen ▸ Air actions.
2. Tap “•••” (More options) at the top right → choose “Reset S Pen” or “Reconnect S Pen”.
3. Wait for it to pair — you’ll see “Connected” once successful.
(Tip: keep the pen close to the phone while reconnecting.)
⚙️ Step 3: Reset S Pen Settings (if still not connecting)
2. Tap More options ▸ Reset S Pen → confirm.
3. Reinsert the pen and wait for it to reconnect.
🔋 Step 4: Check for Updates
Go to Settings ▸ Software update ▸ Download and install — sometimes firmware updates fix Bluetooth/S Pen bugs.
Also check Galaxy Store ▸ Updates ▸ Air command / S Pen Air Actions plug-in — update if available.
🧼 Step 5: Try Safe Mode (optional)
Boot in Safe Mode to rule out third-party interference:
1. Press and hold Power key → tap and hold “Power off” → choose “Safe mode”.
2. Test Air Actions.
If it works in Safe Mode, an app is interfering — restart normally and uninstall recent or battery-optimization apps.
🧩 Step 6: Physical S Pen Check
If none of the above works:
Make sure you’re using the original S22 Ultra S Pen (other S Pens won’t connect for Air Actions).
If you replaced the S Pen recently, it might not be Bluetooth-compatible.
